Thread: Diff questions
Serum
Serum's Avatar
04.18.2008, 11:13 AM
@rhylsader;
the problem with the kyosho cups or the HB C8019 is that you need to use the unneeded expensive blocks from nitromods. (which wasn't his idea in the first place btw, he simple stole it and hit the market with it) the aluminum HPI cup covers this problem in an even better way. I use shims inside the diffs a thin layer of springsteel sheet. (which probably isn't needed with the 'new' HPI diffs)
And i don't use the paper gasket either, i use blue loctite. It seals it up very good, and it tightens up even better.
The GPM housings are available on ebay. The bulkless of FLM is a tad too heavy for my likings. I want to put mine on a diet once i've got my things up and running.
