VintageMA
VintageMA's Avatar
04.22.2008, 01:50 PM
Jeff - I'm using the MA 3S-5000mAh packs (about a year old now, but were strong when i first bought them).
I started out with the same motor as you B50 8L and was getting just about the same runtime as you. Then I got the 1930/6 and with the same gearing got a great speed boost and things were just in check (if maybe close to the edge).
With the RCM extended chassis and 30 series wheels it seems the current draw has gone straight through the roof.
I actually REALLY like your idea on re-configuring the LMT to a 1930/10 to lowe the KV - I hadn't even thought of that. I didn't want to have to ditch the LMT - I love their motors. Are you sure changing from a delta to a wye config will produce that end result?
“Everyone has a right to be stupid; some people just abuse the privilege.”
