sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
04.22.2008, 02:03 PM
Hm, your bashing style sounds very similar to mine, because it's pretty freakin' flat around the house. I probably run mostly on concrete tho. I still dont' see high temps. *shrug* Sounds like the drivetrain is set up just like it's supposed to be. Have your entered your stuff in the top speed calc to see if it's set up to run the speed you want? it's possible it may be set up to run much faster, but they system can only pull it so far (which may lead to the hot batteries you describe).
I would warn against a Quark. I have heard of many many instances where 6S = smoke. As far as i'm concerned, where big ESCs are concered, the MMM is the only way to go. We all know it's going to be designed beyond tough, and their CS is excellent.
