VintageMA
VintageMA's Avatar
04.22.2008, 02:41 PM
Well, the extended chassis added some weight, and the larger tires effectively increased your gearing, so that makes sense. I would've gone down at least 2 teeth on the pinion to keep close to the same roll-out ratio and to help compensate for the added weight. Of course, this assumes you don't mind losing a bit of top speed.
Unfortunately, when I put the larger wheels on, I did re-calculate for the larger diameter and went from 17/46 to 14/46. Still heavy current draw.
Running 3-10-1 for differential weight (even put in new oil when I broke it down and moved to the new chassis) to prevent too much unloading to the front wheels - wonder if that may be affecting things.
It's weighing in around 4.5lbs - is that consistent with you guys?
“Everyone has a right to be stupid; some people just abuse the privilege.”
