TDC57
TDC57's Avatar
04.23.2008, 12:18 AM
I explored this option when I was building my GEVO (GorillaMaxx E-Revo) I was informed by GorillaMaxx and by Mike @ RCM that it was not possible to install the 3905 Trans in the GR3. I never looked at the option for the Revo trans, (sorry cant help you with that one).
I've had quite a few BL systems with custom chassis and I’ve had nothing but great success with the GM single speed transmission, you can also incorporate the new 3905 slipper system on to it by buying the output shaft off a Revo 3.3. Shorting the end 7mm and re-drilling the hole (and I can send you pictures if you would like??)
I do know that FLM does make an adaptor that allows you to install a 3905 in there chassis but that's another Thread / story..
Best of luck and keep us updated on your build.
Nothing!.. Hahahahaaa..
