Originally Posted by BrianG
Yes you can, but the pack with the BEC will drain faster than the other one. This will cause uneven pack discharge, which will cause the LVC to not work quite right since it just sees total voltage.
I run no LVC anyhow. I do 10 passes before re-charge. Your top runs will come on the first 3 passes...that is it. Been there done that. After that as you can see in my video, the truck starts to slow down little by little.
