TDC57
TDC57's Avatar
04.23.2008, 07:10 PM
Originally Posted by GorillaMaxx360 View Post
I ment the drilling on the revo input shaft. How exactly did you drill that (revo shaft) out using the drill press because my bit just wont eat through that steel. what bit are you using and are there any strategys i am missing. Also out ouf curiousity about how far apart is the new hole(the one you drilled) from the existing one on the revo shaft.
I can and will answer all of your questions this evening with pictures!, but for now please review the following link?
http://www.rc-monster.com/forum/show...ht=MAXX+TRANNY
Ps.
You need a titanium drill bit to drill through harden steel. I just got one from Homedepot for $6
You will also need a guide to drill the hole straight, I used a second gear of the stock 3906 transmission or you can use any of the existing gears off the Revo output shaft.
Again I'm sorry but I'm on a conference call now and will not be able to do this until this evening..
Hope this helps??
Have a great one –Shaun
PS. the hole you need to drill is just behind the existing slipper hole, drill it as close as possible to that hole and then cut / grind down the end of the output shaft to the end hole.
Nothing!.. Hahahahaaa..
