rabosi
04.24.2008, 12:38 PM
JZ you're doing your runs at an airfield correct? If so, couldn't you slowly spin up to speed to compensate for the high current draw at start or would that not make a difference? Also if you used Fm crystal type tx/rx would it be possible to use 2 tx's (one tx at 1/3 point the other at 2/3 point) with 1 rx for extended range?
