04.24.2008, 10:56 PM
It's about 6.75" long by 1.9" wide. It fits the long Enerland, NeuEnergy sized packs. The shorter Max Amps sized packs will work too with some spacers.
It uses all four motor mounting screws toward the rear. You can see part of the tray sticking out to line up with the inside motor mounting screws. It also uses the stinger mount screw in the front and couple of others. After I saw my picture here, I added the splash guard screw for some extra insurance. I had to drill/tap those myself.
No, the screws are not included, but you should have them! It uses the original/extra screws from your no longer needed nitro stuff. It is tapped to fit those screws. It uses only existing holes so it can be changed back to nitro if you so desired...I don't desire.
