Holes.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Holes. - 04.25.2008, 09:16 AM
Funny you should ask that question. I just read a fix-it post the other day and I was kind of suprized when they said to use baking soda to fill the hole first and then to drip super glue into the hole to fill it in. They say once it dries you can drill it out and rethread the hole for use. Personally I have used Epoxy to fill up oversized holes and do the same thing. You just have to pick the kind of Epoxy to suite your needs for toughness. Good luck with that.
