bustitup
04.27.2008, 03:00 PM
Originally Posted by Sammus View Post
Is that the 3905 tranny and the 3.3 (extended) chassis? Is there any trick to get it to fit the chassis? I want to do the same to mine so I can run batts either side.
Or to make sure you could use 2 rears from the 3905 max (about 100mm long)
Sammus
its a 3906 tranny...I personal like it better because if your going to run two batteries the 3906 motor mount keeps the motors pretty much centered where the 3905 is lopsided and one of the motors will stop you from mounting a battery on that side
as far as it fitting ...look at post #2 in this thread and look at my under carriage you can see the trany placement ...just hold a emaxx tranny in the hole and you can see where it needs to be dremeled
yes I ordered a set of 3.3 revi drive drive shafts and if they wont fit i will order the two rear's off of a 3905 emaxx and trim them to fit
Thanks for the compliments guys....i'm real proud of this build from scratch...its very rewarding
