Backfire
04.27.2008, 08:48 PM
Yeah, I am sorry about the pic! I should have some better ones tomorrow. I got mine from the US distributor too; but I work there so I get to measure shipping times in minutes to drive home instead of days to ship!
The diff height is a pretty easy fix. You can use several shims like I did to raise the 808 mount to match. I think it is about 3mm shorter than the RCM Mount. I will use the XT8 diff mount, #354011, once I find mine! Then I will only have one 1mm shim under each tower to add clearance for the motor. Ideally, I will probably talk to a local buddy to make a new mount that raises the motor relative to the actual diff and the bottom of the mount. If I decide to use the stock steel 42T gear, then I could keep the diff as low as possible in the chassis.
The new gearing for the 808 creates some options/problems. The new gears in the 808 give you a 43/10 ring and pinion. Th stock 808 nitro gearing is 42T/16T for the spur/clutch bell which is a bit taller than the previous XRAYs. This is probably due to the lighter weight and improved acceleration allowing for taller gearing. In the past, I have used the composite 46T diff gears on my XB8 conversion. I have spent most of my time at a small, indoor electric only track, so the metal on metal noise with the stock steel spur gears was pretty obnoxious. If I try to use the 46T gears for the 808, I am going to need to add about 4 teeth to get back to a similar final drive ratio. That would put me at 18/46 for the small 1/10th track I have been running at. For a larger 1/8th track, I may have to go even higher! The problem with this it it puts the motor way out to the edge and clearance with the side guard may be an issue.
Moving the motor out wide may help with the balance though. Currently with the 4s 5000mAh and Mamba Max on the left side, and the 1512 and receiver on the right side, I am heavy on the left! Moving the weight of the 1512 out on the edge may help counter that without placing additional weight to the right. I have also been considering a lighter 3S/1509 combo, and the 808 would probably be a great candidate due to its lighter weight. This would also help with the balance, removing more weight from the left side. The spur gear is currently the limiting factor for how close to the center I can mount battery. If I am will to deal with the noise, dropping to the stock 42, or the optional 41T spur gear will allow me to move the battery closer to the center. I may try this first since it is quite a bit less expensive than a Neu motor and new 3s battery just to test! I could also mount the ESC on an elevated mount off of the center diff, but I would like to keep the CG as low as possible.
As far as build tips, I don't have anything that sticks out. XRAY has released a tip to remove the inner seal on the pinion gear inner bearing. That tip is listed on their site. Other than that, the kit just falls together like all XRAY kits. I usually build my shocks and diffs first so I can get the messy part out of the way! Rocco should be posting his current base setup on the XRAY site if you want a guide to base your initial setup on. He has been working on a good base setup that is easy to drive. The team continues to test and adjust their setups as they get more time with the cars, so that may vary from the kit setup as we continue to learn about the 808. My previous 4S/1512 setup was within a couple ounces of the nitro counterpart, so I was able to use a similar setup to the team with pretty good results.
Bryan
