DrKnow65
DrKnow65's Avatar
04.30.2008, 12:56 AM
here are some constructive links...
First sikes outrunner e-maxx http://www.rc-monster.com/forum/showthread.php?t=9493 A real good guy to follow if you are looking into an outrunner. He's played with Direct drive revo's and outrunners galore. He even has hand wound an outrunner to make it perform better.
A link to the tamiya (thanks to five-oh-joe) http://http://www.tamiyausa.com/product/item.php?product-id=43532 a good demonstration of how-to.
You guys should offer advise, but keep it constructive and positive. Takedown is obveously a thinker, he's come here and thrown out an idea, asked for help with it, and even drawn us a diagram of the parts so we can see what he's saying. He could have come to some good conclusions on his own given the time and the encouragement. Every successful inventor has built on an idea that failed and was evaluated as to why. More attempts were made and failed again. The process repeated until the awnser was found, then it was something to behold.
That said, there is merit to only using one end of the outrunner, you eliminate the torsion of having the front end inertia fighting the back end inertia. How many outrunners have you seen that actually snapped the output shaft from it's own torque?
I would think that the most stress free outrunner/ center diff setup would be an open center diff with some insanely thick fluid, a pinion gear mounted directly to the outrunner via a slipper clutch, you could add a secondary bearing support on the outer part of the pinion gear shaft, and of course overbuilding and underusing every component. That's me and I may not see something Takedown might. He might throw out something and not see something I do. If we're going to help, we should.
I, personally, would like to drill out the shaft of a large outrunner (mabey an 8mm shaft) so that I could put a 4.5mm shaft through it. I would then put it directly in line between the center diff and the rear end. Connect the motor shaft (8mm with a 5mm hole in it) directly to the diff case (via a slipper) and let the rear diff output go through the 4.5mm shaft to the rear end. The outrunners mass would be low and centered, the center diff would keep the front and rear ends from fighting, and the slipper would keep the gears happy. Use KV and voltage to tune the setup like sikes did with his DDRevo.
Now look at the little blue writing at the bottom of my post to figure out why it's only an idea.
