Originally Posted by aqwut
Jzemaxx... you seem to be pusing that 1521 to the limit... and it's working great.... I can't believe that small motor is able to push that heavy truck to those kinds of speeds.. I guess that's the power of 4-pole motor & high rpms... that's awesome.. I can only image how powerful the 1527 will be...
I would imagine its got to be coming to the end of its power. Cause its staying cool (~108-115) after each pass, but the controller is getting to 185-200 after 1-2 runs. Guess its overgeared. I will probably back down on the gearing which might hurt the speed, but I don't feel like replacing controllers every 2-3 runs. I don't think the voltage is hurting it at all, its just the amp draw must be nearing 200 or so at the top end cause that is went it puffed, puffed...hehe. Leaving the line its great cause I have the soft start enabled.
