DrKnow65
DrKnow65's Avatar
05.01.2008, 10:05 AM
I'm with you there JRH, I put it on photoshop 11 and blew it up, cleared it up as best I could, and still can't make out the numbers well enough.
Linc, It's just hard to fit HV into this little buggy. I need to get a better understanding of how to calculate the wattage different KV motors pull at different voltages. I do have a 2300KV ammo motor that I turned the shaft down to 3.2mm and use in this buggy to make it more raceable on the micro track at the nearest hobby shop. I guess I could get a 5S pack to get the performance back, but can I find one that will give me similar performance to the 5700/3S/5000mah and not weigh a ton?
