B4maz
05.02.2008, 09:38 AM
Hey Tash, you and Blunted(Mr. 49V dragracer) are the highvoltage junkies at Hamdrl.
Bmaz, I'll see if I can make it Saturday and make a run with the pancar. Won't be as fast as yours ofcourse, but Tash's might be right behind yours(if his gears hold up).
sweet. more the merrier. I'm going to worry about my gears too. The problem I am having is that the motor shaft is mild steel. It isn't hardened and the set screw has a problem staying tight.
