VintageMA
VintageMA's Avatar
05.02.2008, 10:52 PM
Just a quick update on the results of this test:
Got a chance to run the CRT.5 with the TP2600 pak for the first time. It was kinda drizzling outside so was running a lot of wet grass so that gave a bit of rsistance, but I was very excited about the fact that with the left and right side of the buggy almost completely balanced within about 20 grams the buggy tracked prfectly straight accelerating and braking hard - no more pulling to the left or right because of a neavhy battery pack. With the lighter pack buggy weight was almost .25 lbs lighter - max Amp draw dropped to 53 Amps.
I think because of the think wet grass overall amp draw was up a bit so runtime was a bit shorter - only 9 minutes running very hard.
I'll have to try the exact same setup I did with the 4000mAh pack over the weekend and see what runtime is like.
“Everyone has a right to be stupid; some people just abuse the privilege.”
