Just go Play
Just go Play's Avatar
05.04.2008, 03:56 PM
But could you tell me where is this reset button???
When i open the program on my computer, i can't see any reset button
Another thing, have you try to run your controler on cut off mode???
For me, when i run in cutoff mode, the controler "cut" after only 4-5min of run, but if i put it on reduce rpm mode, i can dump my pack without any problem, and i can't observe any reduction in performance thrue the pack.
I've a Flightpower 5000mAh, 4s.
Thank you!
There is no reset button... the one you want is the defaults button located bottom left side of the program window.
Yes I have a problem with cut off mode getting tripped earlier then reduce rpm does. I have old firmware so it's expected, but that is the only real problem so for me it's not worth it to send in for updating. Once I get the new mamba then maybe I'll send the MGM in. Maybe by then they will have a fully functional firmware ready.
