david lamontagn
05.04.2008, 05:12 PM
Originally Posted by Just go Play View Post
There is no reset button... the one you want is the defaults button located bottom left side of the program window.
Yes I have a problem with cut off mode getting tripped earlier then reduce rpm does. I have old firmware so it's expected, but that is the only real problem so for me it's not worth it to send in for updating. Once I get the new mamba then maybe I'll send the MGM in. Maybe by then they will have a fully functional firmware ready.
So i suppose you run it in reduce rpm mode?? And do you feel any sign of power reduction during your whole pack?? Do you feel that the controler reduce the power and the rpm of you motor when the pack is 1/2 or 3/4 empty??
And is the auto tuning realy help with performance or the controller??
If i experiment any lost in power in reduce rpm, i'll run it on race mode for sure.
