DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.04.2008, 05:57 PM
15 - Relates to the rotor diameter. (in MM?)
09/12/15 - Relates to the rotor or motor length. Larger numbers means a longer motor.
1.5/1/2.5 - The number of turns
d/y - The coil configuration: d=delta/triangle. y=wye/star
f/s - f=finned can. s=smooth can (which can sometimes just be nothing)
You will have to run a mod 1 pinion
http://www.rc-monster.com/proddetail...1pinion&cat=40
I am running 37 000rpm in my 8ight. If you are looking at running 22v I would look around the 1500kv motors
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
