05.09.2008, 03:08 PM
Unfortunately, unless the PSU tells you which rail to load, it's a bit of trial and error.
Can't remember where I got my shims - I think I just collected them over time and happened to have the ones I needed. Just use your bearing size to determine the size of the shims (and don't forget; the shim width cannot span both edges of the bearing or it'll rub).
