Thread: Nosediving Neus
Mozzy
Mozzy's Avatar
05.10.2008, 12:13 PM
Don't give up your day job, cause, you're a crap comedian.
If you took the time to look at commercially available conversions, the majority offer the mechanical braking as an option.
The Tekno Revo conversion uses the existing brakes as do alot of their buggy & truggy conversions.
This is directly from their site..........
Uses stock mechanical brakes so you can tune front/rear brake bias if using the center differential kit. This results in much more predictable braking and less heat generation compared to using 'motor braking', not to mention it will save your transmission from unneeded stress.
The only good thing those rocks are for is to throw at your head.
Look before opening mouth.
