05.10.2008, 02:31 PM
Anyone for toast?
Well, today I went to the park with the truck, and had a real rollercoaster ride. I plugged in my 7cell Nimhs using my series adaptor, turned on the radio, then went to 'arm' the system by pluging in the BEC (leaving the esc turned off as per the instructions for running a single large battery pack), and the truck took off at full throttle! I slammed on the brakes, and the truck came to a halt, but a thick cloud of white smoke rose up from the truck, and it tried to take off again, but then on hitting the brakes for a second time the truck stopped dead and the smoke cleared- all this whilst I ran over to the truck. Seems my little BEC didnt like 16.8v going through it and let out the magic smoke before dying- as you can see in the photo, the posistive lead melted clean off the board. I then spent the next half hour trying to get the truck running again without the external BEC; in the end it seems that as I yanked out all the plugs from the radio to kill the smoking BEc, I plugged the throttle back into the wrong slot and had my steering mixed with the throttle.... Well, I figured it out in the end, and managed to get some nice video of truck running with my cheapo lipos; wow....
Video to come shortly, just need to edit it up.
The LVC (that is it on the antenna, correct) worked like a charm. it would glow red under hard acceleration, but would quickly go out once the truck was moving. I got roughly double the run time of my Nimhs when using the Lipos, and Im amazed how much punch they have, and continued to have all through the run. Even towards the last few minutes when the LVC light was staying on to indictate 3.0v per cell, I could still wheelie the truck fro a standstill, or from anything upto about 10-15mph, as the video will show. Not bad at all for $20 lipos....
On the shock front, Im going to say that rears would be better than fronts, and that you may well need 4 on the rear of the truck, and two on the front. The truck did handle really well when flung it into corners, but the rear would squat a fair bit under acceleration, so I think Im gonna pick up another pair of shocks & another pair of the purple rear springs, just to stiffen it up abit.
On the damage front, I killed the BEc, and at one point lost a shock- the screw holding it to the A-arm came loose, so I just need to add some loctite in a fair areas. I also dislodged the rear body posts from the tower after a violent wheelie; truck slammed back onto its lid, then back down onto all four wheels- did that a few times during the run, lol.
I also recorded some temps during the runs, makes for interesting reading:
NIMHS:
Motor = 109
Esc = 90
Batts = 150
Lipos:
Motor = 130
Esc = 110
Batts = 110 during run, 120 at very end of run.
In the old days the esc would rarely get much above ambient, as was the case today with the Nimhs, but when I switched to the Lipos it seems have made the motor really come alive, so amp draw has increased, and the esc was alot warmer than usual, same to with the motor. The batts stayed quite cool during the run, but towards the end I did about of a torture test and ran full throttle for a good minute or so back & forth, then brought the truck in to end the run and check temps.
I think Im also gonna pick up one of those nifty little voltage checkers that you plug into the balance taps on lipos, just to be doubly safe- they only cost about $5 or so and its a worthy investment.
