George16
Supermaxx
George16's Avatar
05.13.2008, 11:35 AM
Originally Posted by austinelse View Post
Hi Guys,
Austin here with MaxAmps. The speed control does not determine the amp draw, the motor does. If the motor is pulling more than 120 amps constant, go with an 8000 pack. Most people are going to want more than 3 minutes of runtime anyways.
For the record, MaxAmps packs can be used with the MMM speed control. Depending on what MaxAmps pack you are using and the amp draw of the motor, you may need a different pack. I think that is what castle is trying to say. If you try and run any 4000mah pack with a 200 amp constant motor, you are going to have trouble. It has nothing to do with a MaxAmps pack vs another manufacturer.
Hope that makes sense,
Austin
CEO MaxAmps.com
Help me understand better how the MaH of a battery make a difference in the amp draw? I thought the discharge rate such as 25C and 30C makes the most difference in amp draw and that the MaH affects mainly the runtime.
