rootar
rootar's Avatar
05.15.2008, 08:09 AM
Originally Posted by jordan... View Post
Thanks for the comments guys
Good idea with the (non)coloured lipos, the reason i decided Neu is because they have a 5000mah 30C pack, whereas the 30C Flightpower only goes up to 4900mah, probably not a huge difference there though Might have to consider that shrink wrap idea of jhautz, it would look alot neater with black packs.
As for the CF vinyl, i got it from Tower, search through the manufacturers for 'Upgrade RC', they make loads of different vinyls for wings, radios, wheels, even pit chairs!! It turned out alot better than i thought it would!! They make a whole buch of different designs as well, so yeh, check it out.
thanks for the comments
jordan
Have you looked at the two 5000 batteries nue has, one is the 30c as your looking at and then they have the 25c and the only differances between the two are 125amp/150amp continous, the 30c is 23mm longer and 25 grams heavier........i didnt know if you had seend that or not and was still going to run the 30c even though its so much longer, i am looking at the same battery for my setup, i saw one place that had either pack for $220 each, i thought that was a good deal but id have to look through my histroy and find it if you wanted the site.
