Thread: 2p charging
skellyo
skellyo's Avatar
05.15.2008, 09:59 AM
Originally Posted by tom255 View Post
I cant confirm that actualy. Usualy after couple cycles I balance cells on every pack separately becouse notices that cells no not stabilize each other. If one cell is 3,5V and second paralel cell is 3,7V on avaraege shows 3,6V if both batteries connected parallel. Whats why i do it.
And if packs are same type and brand etc parallel using should do OK.
If they are not equal I am not recommend to doi it because difference in cells will rise and avarage can be OK but for example one weak cell will be over discharged.
Ideally, the higher voltage cell charges the lower voltage cell until they reach an equilibrium, but it must be such that Lipos would need to be paralleled for a long period of time to do so. TrueRC and MaxAmps both build packs with cells in parallel, but with the cells constantly connected, it should be much eaiser for them to maintain equilibrium.
Based on what you've personally experienced though, I can't help but recommend separate balancers for each pack.
