05.18.2008, 10:30 PM
Originally Posted by jfruge View Post
Here is my current setup. I need to work on an antenna mount for it. I have the 36-50 2000kv with 12/46 gearing. I just took a few passes today on the street. What are some steps I can take to keep the ESC cooler other than a fan on 4S ? it was about 95F here today and after my short run the motor was about 105F and the ESC 125F.
What are your esc settings? You could up the timing and see if that helps? From what I can gather the higher pole count motors prefer more timing. You could also turn down the punch control.
Maybe open some cooling holes in the body, and add a fan.
