05.19.2008, 10:32 AM
You could also feel your solder connections after a while of running. If they feel warmer than the wires, you could be getting voltage drop on the connections at high currents.
As others have said;
1: Get batteries that can handle the load without as much v drop
or
2: Get higher voltage and higher wind motor. A 10XL or 11XL on 5s or 6s should do nicely.
or
3: Simply gear down. You won't get the same top speed, but your batts will thank you.
