rootar
rootar's Avatar
05.19.2008, 08:21 PM
yes you can run two 3s 5000mah packs in a series to make one 6s (22.2v) 5000mah. if you really plan on doing this i would goahead and order your other 3s 5000 pack and try to alternate which one you use in the slash to keep the same number of cycles on each so that they will be as equal as possible when you hook them up in the revo as one pack.
someone else correct me if im wrong but i think your supposed to keep the same number of cycles on each of the packs if you run them all the way to cutoff voltage in a series very much so that one pack doesnt drop a little bit below the 3.0v per cell accidentally.
