bl-is-future
bl-is-future's Avatar
05.20.2008, 11:11 AM
Main reason for locking a 2 speed in one gear is to eliminate the one way bearing and use the motor brakes. If you do not mind mech brakes you can leave the 2 speed. My savage has that setup and it works fine for me. I did some adjustment to get it shifting at the correct time. I think I raised the shift point, so it would stay in 1st longer.
K thank you now i realize the point of it. Yeah i use the mechanical brakes so i will just make adjustments to make it shift. It is the 3 speed too so that is why i really want to use it instead of locking it in.
