xtremelimits285
E8ight T
xtremelimits285's Avatar
05.22.2008, 09:41 PM
I used the live in South Florida and it gets hot there. If it has a fan, just use it. I've had 2 pole motors heat my controllers more then multi pole motors. Your controller might work twice as hard, but the 4 or 6 pole motors will produce more torque and require less AMPs to make your vehicle move. If your fan does fail, do like jhautz did: http://www.rctech.net/forum/showpost...postcount=6753
i already have 2 fans like, that the other day when i saw that post, i know thats how ill run my fan(cus lots of MMM 's fans are breaking on like the first run)
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
