Shark413
Shark413's Avatar
05.23.2008, 01:27 PM
I built a servo mount last night and installed it in my Kyosho buggy. The original design I used with the stock servo plate had a lot of flex because it had only three mounting points. The new mount is much stronger, and the best thing is I can remove two screws and the entire brake servo can be swung out of the way for access to the pinion/motor mounts and the brake/servo adjustments are not impacted.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
