lutach
lutach's Avatar
05.23.2008, 05:03 PM
Originally Posted by TexasSP View Post
Are you using the 120 amp 6s version right now? Is this the same model as seen on fleabay or different in some way?
Also what is the expected cost to be of the 12s version? I assume the difference between the two 12s versions will be amperage, what will the two options be?
The one I have is the 120A 6S, but the ones being sold so far are for aircraft only. This is the only unit I know of that has the car/b mode working. Scorpion will go with a new PCB for the new units to lower the resistance. They are 1% lower then Kontronik and Georges doesn't like that. The 12S will be 90A and 130A and I don't know what AMP rating the 15S is.
