05.23.2008, 10:50 PM
Originally Posted by Kenny135 View Post
I am going to be converting a Hot Bodies Lightning GT10 to brushless and I want to buy a Neu motor to use with my conversion. I want to get ether a Neu 1509/1.5D motor or a Neu 1512/1D motor, I plan on using this motor with my Mamba Max ESC with a Trackpower 5400mah 3 cell lipo. Which one do you guys think is better and why? Thanks for the help.
The 1509 will most likely be fine. I run my LS10 with a variety of motors, and anything about the size of a L can works fine. The 1509 will make plenty of power, the 1512 may be a bit much. Plus the kv is a bit high, you could get away with a lower kv, like 3500-4000kv.
