Pressed
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Pressed - 05.25.2008, 03:27 PM
That gear has to be pressed on the rotor shaft. I seriously doubt that they made a rotor shaft and milled a pinion on the same piece of metal. You may have to apply a little heat to the gear to get it off. Wish you luck with that project.
