azjc
05.25.2008, 04:45 PM
Originally Posted by blueb8llz View Post
so how do you plug those lipos up to your esc. his esc uses dean plugs. does he need to solder them plugs onto the lipos...where? those trackpower and teamcheckpoint lipos look very different compared to other lipos.
and is he only limited to those certain lipos...like can he use those zippy's or the ones by truerc?
he could use the others as long as the output jacks on the charger are 4mm banana jacks the balancer would plug into those jacks and you can also buy balancer adapters too
the True Rc lipos take a hyperion type and the Zippys are XH
this link has a table to what adapters will fit what companies packs
http://www.allerc.com/product_info.p...oducts_id=3159
