GriffinRU
05.26.2008, 11:36 AM
Good call Daniel, but he still needs to restore connector, otherwise he cannot re-program it or cannot enable/disable BEC, I do not know which one is broken i.e. close to the board edge (usual suspect, programming jumper) or second one from boards edge (enable/disable BEC). If it is BEC's jumper than he is Ok because he doesn't need it, better be disabled, but if not then restoration required.
To evader:
You can send it to me and I will recover it for you, just cover the shipment cost ($5.00 by priority mail). If you want I can add couple goodies to your ESC to improve it a little bit. If interested send me PM.
