phatmonk
RC carbon junkie
phatmonk's Avatar
05.26.2008, 05:52 PM
The ceramics show about .005 ohm or so. The inductor isn't as compact as the capacitors because there isn't any inductors as compact as the capacitors -- not really sure what you mean. The smallest 22uh 4 amp inductors are at least 10mm square.
The FETs are snubbed using an RC snubber -- to prevent ringing.
The component that is failing is the switcher controller -- a National LM3485. National is looking into it with us -- seems the overcurrent circuit is failing internal to the LM3485, and leaving the chip in constant overcurrent state. That's why the output voltage drops to 1.08V - -it's in hiccup overcurrent mode. Replace the LM3485, and all works well again.
Patrick
Thanks for your personal involvement in this issue Patrick.Both of my Monsters have died you guys received one of them last wednesday and no one has called me so I am assuming you ars fixing it.It will be interesting to see how long it will be till I get the first one back.I will be sending the other one in when I get the first defective Monster back.I now have no speedcontrols so pleeeeeeeeeeeeeeeeease fix it soon.
thanks
Will
