Originally Posted by lincpimp
This is exactly correct. I run a 6.5 hv motor in a crt.5 on 3s, and it seems like it gould do with 4s. Those novak hv motors really need rpm to produce any power. Go up to 4s and drop to a smaller pinion.
I will 4S a shot and drop a couple teeth on the pinion. Never had these issues on the e-Revo even on 2S - damn thing would run all day. Just remembered, I was running a BEC on the Revo. Might try that and see if that helps also.
