azjc
05.28.2008, 06:49 PM
If it is running without the set screws, it is on there pretty good. I think heat and a gear puller is the best answer - any hardware store will likely have a small gear puller that would work. Next time, you may go a little lighter on the threadlock (only a little dab on the set screw is needed - blue loctitie). :)
I have had a pinion stuck on a shaft without using any threadlock
