Sammus
Sammus's Avatar
06.01.2008, 11:19 PM
Originally Posted by dirt101 View Post
well heres my question. can 4mm plugs be soldered on the GIGANTIC 10g wire? Im not sure if there is enough clearance.
and is a 4mm plug enough to handle a 1515 2.5d on 5s in a CRT.(geared for 37mph)
I use 4mm connectors (stock sidewinder esc) on my CRT.5 running a Feigao 9L and 3s, geared for about 34mph on brians calc, nothing ever gets the slightest bit warm so I'm thinking the 4mm spring connectors are up to the task.
