VintageMA
VintageMA's Avatar
06.02.2008, 04:32 PM
Originally Posted by SpEEdyBL View Post
If castle is listening think there needs to be a programming option where you can set your own auto detect voltage. e.g 12.8 volts if a 4s pack is detected and 16 volts if a 5s pack is detected, otherwise it would be PITA to have to reset the cuttoff every time you alternate between packs.
+2 on that. If this is all done through code a firmware update could be all that's needed to make that adjustable setting. That's been a real issue for me because I do like to run different packs while I am out and have to stick with the auto-cutoff as my only choice.
“Everyone has a right to be stupid; some people just abuse the privilege.”
