VintageMA
VintageMA's Avatar
06.02.2008, 05:04 PM
Originally Posted by Sower View Post
I don't get it . . . changing the voltage drastically changes all the characteristics of the system. I think most people set up a system with an end use in mind and stick with it. Why are you changing the voltage for your systems?
Generally I agree, but I can think of two scenarios:
1) HV - the more cells you use, the less of a difference a change makes. If you are using 2 cells, then yes going to 3 is 50% more speed. But if you are using 5 then going to 6 is only a 20% change. I have a setup that is going to be a nice powerful ride on 6S geared for ~42-44, but will want to drop down to 5S for some calmer driving around.
2) Doesn't apply to me, but if you have an ESC you want to switch between rc's with different setup it would make things a little easier than having to reprogram every time.
“Everyone has a right to be stupid; some people just abuse the privilege.”
