skellyo
skellyo's Avatar
06.03.2008, 09:49 PM
Originally Posted by speed demon View Post
Let's say for instance on my rustler with the medusa motor running 4S then putting in a 5S but gear it down too the same speed will I have the same run time given both bats are the same mah?
It's unlikely that scenario will happen. You'd have to make sure that the gear reduction itself reduces the current draw by roughly 20% with the 5S setup. I'm not sure that gearing for the same speed with both batts would do that. I think the only way you would really know how close you can match the current draw of the setups is to run them on an Eagletree or similar datalogger.
