Thread: MMM guts?
GriffinRU
06.07.2008, 12:06 PM
Artur, from what you've seen on the MMM so far, is there a way to save an ESC when the BEC fails without sending it in for repair? Like maybe disconnect a BEC component and then use an external one? I've heard a few people blow a repaired ESC which leads me to believe the issue isn't totally worked out yet. I'd rather take a hit on the warranty and mod it then send it in again. Besides, I've already modded it to my liking.
If you remove inductor then you should be fine using external BEC, but the best would be to remove lm3485 and 2 fets.
