hekekorte
06.11.2008, 05:15 AM
Originally Posted by GriffinRU View Post
eMachineShop files,
Thank you GriffinRU for the .ems files. A 3d view shows that the another, heavier copper part is u-shaped, but in your pictures they both are flat. Are the flat ones just a simplier way to do the mod?
Zeropointbug: do you have dims for your clamp parts?
Generally: Would there be any sense to separate the power section from the brain section? To my knowledge it needs only some extensions to wires. It may be easier to put compact heatsinks to both fet sides and take the brain section which does not heat to more "safe" place to avoid short circuit and hit. Longer wires in this case are not length sensitive, I suppose? Just a thought...
