06.11.2008, 11:32 AM
If you look at the pic below, you'll see that the PCB and case are seperated by a heat spreader. The PCB and case are attached to that heat spreader via a thermal sticky pad. You have to insert a thin screwdriver between the case and the heatspreader do NOT pry between the case and PCB!
