lutach
lutach's Avatar
06.12.2008, 09:59 AM
Were you using the same gearing on 4S or 5S that you have with 3S? If so you, everytime you go up in cell count you will only be drawing more AMPs. Try a smaller pinion or a bigger spur and gear it for the same speed as you were getting from 3S. My 1521/1Y on 10S lipo with the same gearing I use with 6S will draw a lot of AMPs.
