azjc
06.14.2008, 10:20 AM
Originally Posted by patxeik View Post
i tried a 8xl on the truggy with the 62 spur gear and it wasnt as fast as the 9l like you see on the video, now i have a 7xl that i will run on the revo but maybe i will try also on the truggy.
The 8xl died in a jump on the revo, the front end bell poped out
whith your 8XL system I would have geared up to the 46 tooth spur the larger cans can handle the gear change better due to the increased torque. What size pinion were you using? I would go with a 14-16 tooth ...but the reason your 9L got so hot was it couldnt handle the gear change
long story short
truggy/monster truck-XL can
buggy-L can
and if you need more vehicle speed increase pack voltage or gear up this will result in a happier(cooler) system
