Cain
06.15.2008, 12:02 AM
Originally Posted by tom255 View Post
50mm motor came with flat spot on full lengt on shaft.
Does the 60 2000kv V2 come with a flat spot??
Can someone explain the 920W, 87A, 105A, and 30V values as far as how they relate to each other for this:
MR-036-060-2000V2-5 2000RPM/V 1.70A 0.006 920W 87A 105A 30V 36 x 60mm
Is 920W the watts that can be produced sustained or peak? Would a peak for this motor be 105A x 30V = 3150W??
Assuming a 14.8V setup that is rated at 120C continous, how do I determine the possible amp draw on the batteries, or, is it limited to a max 105A?
Trying to decide on some batteries here but not sure if my max amps rating that would be pulled is 105A by the motor, or thisL
3150W / 14.8V = 212Amp peak? (got a chart here that breaks it down this why by different voltages)
